Home > General > Air suspension fault.
Amrik
Looking to buy range rover for friend. What are the ways to see faulty air suspension[/u]
Post #525017 Mon May 01 2017 7:56pm
Tim in Scotland
Lop sided car (higher / lower on one side compared to the other), activate the ride height button and see if you get any warnings in the dash about slow raising, check in the 4x4 info screen that there are no red bars showing above each wheel, sometimes you can hear strange noises as the car raises or lowers. It should go up evenly all round, should not go down/ up like a camel, one end first then the other. Sometimes you can hear air leaks from compressor or lines. After leaving the car overnight in Normal height check that it hasn't settled down to access mode, any warning on the dash that the compressor is working hard - can be compressor overheating. It is also better for the car if you don't have the car completely stationary when adjusting the ride height and be sure that the parking brake is off on L320/ RRS1 if you are raising and lowering the car several times in quick succession. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #525026 Mon May 01 2017 9:36pm
Tim,I may well be wrong here but I thought the Rear should raise first slightly when rasing suspension, and when lowering the Front should lower first so as not to dazzel other vehicles when changing heights if the lights were on. Thinking about it though it could of been my old P38 that did it
Post #525027 Mon May 01 2017 9:54pm
Tim in Scotland
You may be right there - the important word is "slightly" which was why I compared it to a camel kneeling down. It is so slight that you should hardly notice it. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #525046 Tue May 02 2017 8:06am
Hi Tim, sorry didn't mean to sound as having a go, probably never worded it very well.
Post #525047 Tue May 02 2017 8:12am
