Home > Technical > Faulty Pasdenger Wing Mirror - Help!
cbayuk
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi All,
I'm new here so please go easy on me. My passenger mirror is currently not working how it should. It operates diagonally i.e. top left to bottom right, however you don't have the full movement and adjustment, any ideas?
Will this be a wiring issue or something faulty? Any suggestions and advice ill be most welcomed. Thanks in advance.
Post #524797 Sat Apr 29 2017 5:36am
Eaters
First thing I'd do is use the button to fold them in and then out again (with the adjuster button in the middle position, push down). Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #524799 Sat Apr 29 2017 5:53am
cbayuk
Okay, will this potentially reset the motor then? OR what will be achieved by this?
Post #524800 Sat Apr 29 2017 6:08am
Eaters
Its supposed to be a reset after its been manually folded in (or out). But can't do any harm. If that doesn't fix it then sorry you'll need someone with more experience of this. It was just a thought and something easy to try. Robin
Gone:
MGZTT 190 2.5
Post #524802 Sat Apr 29 2017 7:10am
cbayuk
Okay. I will try but don't believe it's the folding that's the issue. I'm guessing it might be the motor.
Post #524803 Sat Apr 29 2017 7:15am
cbayuk
Tried this and they folded in fine, but still issue with actual mirror adjustment.
Post #526432 Sat May 20 2017 11:49am
