Home > Faults & Fixes > Another suspension issue. (fixed) |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Need the codes reading really mate otherwise you'd just be guessing.
Sun Apr 23 2017 7:25pm |
Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71 |
eML goes off on petrol |
Sun Apr 23 2017 7:30pm |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
Means your LPG installer did a lot of shortcuts bypassing the O2 sensors. Regards etc.,
Mon Apr 24 2017 7:56am |
It's nothing to do with the 02 sensors it's high inlet pressure |
Mon Apr 24 2017 9:12am |
If we could get back on track
Mon Apr 24 2017 9:13am |
is that a generic code reader your using |
Mon Apr 24 2017 11:27am |
It's my britpart suspension odb dongle thingy |
Mon Apr 24 2017 4:19pm |
You need to get it read with a different code reader as if you put that into google it comes up with different versions and none are to do with land rover suspension as it should have a letter in front as the rest i have seen |
Mon Apr 24 2017 4:24pm |
It looks like an ace issue from the light i think |
Mon Apr 24 2017 4:25pm |
Ok
Mon Apr 24 2017 5:23pm |
Ok so I fixed her, after even the Indy had no clue
Fri Apr 28 2017 8:21pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
Hi all interesting read this as I have the exact same problem and it so intermittent here is what I have checked so far (RRS 2006 Supercharged)
Wed Jun 14 2017 8:06pm |
These cars have pretty big shields underneath, so you may want to remove it and see where the oil is actually coming from. The ACE/DRS system has it's own fluid reservoir that is on the lower left of the engine bay by the off-side headlight, check the levels and make sure there's plenty in there.
Tue Jul 11 2017 9:38am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Whip it up to Mark West at West 4x4 in Bishops Waltham for a look-see ?? Visitor from fullfatrr.com
Tue Jul 11 2017 11:04am |
