![]() | Home > Technical > Egr blanking and engine light |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
Hi mate , I got Bodsy to put a software patch on mine although mine didn't actually put light on, it did register faults . Have you cleared them ? |
is it a bluefin plug in box?
Astra012 Member Since: 31 Aug 2014 Location: Cardiff Posts: 51 ![]() ![]() ![]() |
Will speak to garage and ask them to clear faults again. Its a plug in one had it installed and took it off. Egr valve went decided to get them blanked, reinstalled bluefin. Massive difference in the car just eml on. How do I get a patch installed?
You need a visit from Bodsy and bin that bluefin |
I can do that for you and if you wanted a proper smoother remap instead of just increasing the injector fuel rail pressures.... Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
