![]() | Home > Technical > Traction Control activating on corners |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
It is not traction control that is activating but stability control is kicking in as the systems are detecting some yaw when cornering.
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 ![]() ![]() ![]() |
Ahh yeah, that's what I meant, the dsc.
SAS32 Member Since: 05 Feb 2017 Location: UK Posts: 27 ![]() ![]() |
Your steering wheel angle sensor might need recalibration. |
Already done |
Pleased to hear you got it sorted. |
Hahaha, I meant the steering wheel angle sensor, not the actual issue |
I'll retract that |
Bowesman Member Since: 18 Oct 2016 Location: Leeds Posts: 14 ![]() ![]() ![]() |
Hi TomTerrain,
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
Had the same issue on my D3. Found the rear upper sus bushes were shot on one side which is why the DSC was only kicking on when cornering in one direction only. Replaced bush problem sorted .. 2008 G4 RRSport TDV8 current
thanks Camelrock, will check that out tomorrow. Taken it to a local indy garage but asked them to check the front again due to rough ride, didn't think it could be rear |
Not yet:(. I've been sorting out a new vehicle so not had a chance! I'll check the rear, but I have a knocking from the front, so I'm sure it must be there somewhere! 2006 Java Black HST Supercharged |
Bowesman, have you had any luck?
Hi TomTerrain
Does it squeak when you're going over bumps? And knock when you turn? It felt like there was something loose in the steering!
