![]() | Home > In Car Electronics > How to avoid a flat battery |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Hmmm. Just a few words to help any others as stupid as me. Wanted to pump up the tyres on my bike and being lazy, decided to use the electric pump I carry in the RRS. Used the power socket in the boot and it worked just fine once I had turned on the ignition - just to the first position you understand so that there was power in the rear socket.
Ok to connect the positive direct but negative should be clamped to an earth and not the negative battery post....that's my understanding.
I'm sure I read that somewhere but by o-level physics says " what's the difference?" So I just connected to the terminals |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
People just worry about things sparking near battery vapors and causing an explosion
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
Yep no different to any other car - there is nothing mystical about the RRS if you leave the ignition on in any position and charging the battery is exactly the same as any other car. It is easier to put the negative lead of the charger on the body post rather than try to get at the -ive on the battery but all else is the same.
Riverblanche - on a slight aside - I have two tow sockets fitted (and presumably wired) but have never towed. I believe one is for lighting and the other is for power to say a caravan. Which I would use to trickle charge? And is there a note somewhere about wiring up a plug for this? Robin
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
If you go in the forum shop you can purchase a plug for use with tow electrics and a trickle charge 👍 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Cheers Buckster |
Not sure what charger you have but i use a CTEK via a 13pin on the tow electrics |
White plug for power.
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Thanks for the thoughts and advice all.
