Home > Faults & Fixes > few codes together u0132 u0100 u0133 u0140 u0138 u0159 u0184
damidj123
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi rr sport owners
Im wondering if anyone out there could help me because i have a fair few obd codes all at the same time. I know there are posts out there already with one code explaining what is wrong but i wondered if anybody would have an idea what to change first with all these codes showing at the same time. Any help would be great. Im not a mechanic but willing to try fixing myself.
The codes are as follows
u0132- lost communication with ride level control module.
u0100- lost communication with ecm/pcm "a"
u0133- vehicle dynamic control fail signal.
u0140- lost communication with body control module.
u0138- lost communication with terrain control module.
u0159- no communication with parking assist control module.
u0184- no communication with radio.
b1a00- control module.
b1a14- srs warning lamp.
b1a87- battery disconnection unit reset.
engine system fault.
Ps the car drives fine.
any help ???????????
Post #521380 Sun Mar 19 2017 11:19pm
geoffsnook
Sounds like a battery issue to me maybe a battery thats about to die how old is the battery Thumbs Up
Post #521385 Mon Mar 20 2017 7:32am
damidj123
Hi geoffsnook
I did think it may be the battery because its the original battery from 08 and i used to have an x5 which started getting suspension problems which turned out to be the battery also. I will get a new one and post my findings. Thanks
Post #521393 Mon Mar 20 2017 8:53am
geoffsnook
These things do throw all sorts of faults with a dead or nearly dead battery mine disco 3 did and i have just changed the battery on my sport Thumbs Up
Post #521394 Mon Mar 20 2017 9:01am
damidj123
Hi
I wanted to post my findings and hopefully help people out on this site as it has been a great help to me. I went to see a range rover expert and he did back you up and said a lot of faults does point towards a battery but in my case he said it was 100% compressor (i forget why). I read somewhere to spray water on the pipes going into the compressor dryer to check for a leak because in between them pipes the lid cracks and sure enough there was an airline crack there (very hard to see but with water sprayed on there showed a leak). Got a new compressor dryer lid via ebay £25 and hey presto it works no warning lights. You can fit the lid without removing the compressor.
As for the engine system fault it turned out to be a stuck actuator on the turbo which i sorted for the price of a tin of wd40 and a coat hanger which is also explained on the rrsport website.
Post #523110 Fri Apr 07 2017 10:17pm
DrRob
Forum power Thumbs Up Bow down Visitor from fullfatrr.com
Post #523124 Sat Apr 08 2017 9:08am
