![]() | Home > General > what are the common problems with the 4.2 sc engines |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I have the same car as you and from what I can tell, these engines are pretty good so long as they are serviced regularly.
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
The petrol injectors clog up 2007 SUPERCHARGED HST |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
High-mileage 4.2 SC (as well as 4.4) can have issues with the timing chain, tensioners and guides. This is easily spotted by listening for 'clunking' noise on idle and - inevitably - check engine light with codes for "bank 1 and 2 lean".
