Home > Faults & Fixes > Special programme not available
Bulletsaints
England 2005 Range Rover Sport TDV6 SE Java Black
Only owned my rrs
for 24hrs but when I start it it comes up special programme not available ?. It did say suspension fault special programme not available what does this men please? Suspension seems to go up and down ok. I'm a complete novice and never owned one before
Post #519057 Sun Feb 26 2017 3:27pm
Eaters
Don't know how your differs from my 2008 TDV8 but here's my thoughts:
It sounds like you need the codes read.
Did you purchase privately or through a car dealer? Any warranty? Go straight back to the seller and get him to fix it.
Do you have the off road screen on your touch screen? If so with engine running adjust the height of the car and check that the little lines above each wheel on the display are white. If any red that points to an error in that corner Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #519067 Sun Feb 26 2017 5:53pm
Bulletsaints
No brought it privately, he did tell me about it but I think I just fell in love with it and just wanted it. There's no screen in mine to look at the on screen levels etc just hope it's nothing major as it drives lovely and air bags go up and down ok and I'll never use the off road function
Post #519071 Sun Feb 26 2017 6:44pm
DrRob
Welcome from a fellow Hampshirite Thumbs Up
www.west4x4.co.uk is best independent LR specialist nr Southampton Thumbs Up
I can read the codes for you....at least you'll have an idea of what it might be....
http://www.icarsoft.com/web/icarsoftus/res...fbe_1.html Visitor from fullfatrr.com
Post #519075 Sun Feb 26 2017 7:24pm
If it does it just after you started it, and then goes away straight away it could just be that the battery is a bit flat.
Post #519076 Sun Feb 26 2017 7:40pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Re: Special programme not available
Bulletsaints wrote:
Only owned my rrs
This is what happened to mine and it was the leaking cap on the compressor drying chamber, get underneath rear passenger door you will see an oddly shaped black plastic cover, pretty sure it requires 3 bolts to remove and some plastic tabs around the edge, once off, just spray some fairly liquid an water, if there's a leak it will bubble up .
[URL=]
[/URL]
Have a read through here
http://www.rrsport.co.uk/forum/topic45468.html
Post #519123 Mon Feb 27 2017 10:52am
Bulletsaints
I've spoken to the previous owner and he said it's been like this since he brought it, 2 years he says ? And he was apparently told that the battery died and was replaced at main dealer and this come up on dash ever since. Never bothered him as he had no intention of using off road functions. True or not I don't no
Post #519236 Mon Feb 27 2017 10:32pm
Bulletsaints
Hi mate, yer I used to deal with West 4x4 when I was in the motor trade as a parts sales person. You said about reading the codes ? Have you got something to plug in to get codes or if I give you codes you can tell me what they are ?
Post #519314 Tue Feb 28 2017 12:31pm
