Home > General > Extended Warranty Diagnostic Charge ?
1014rk
Hi,
My RRS is on LR extended warranty. My question is do I have to pay for diagnostics, And if found to be a warranty claim, then I will not be charged �150 for 1 hr diagnostic investigation, however if the claim is rejected I will have to pay the 1hr charge of �150.
My last car which was on extended warranty and I don't remember being asked if I was ok with this diagnostic charge.
Is this the normal procedure.
Thanks
Russ MY 2014 3.0 SDV6 HSE Dynamic
Causeway Gray
My2011 3.0 TDV6 HSE Luxury Nara Bronze (gone)
Post #517572 Mon Feb 13 2017 12:33am
Russben
I've been told the same thing by my RR dealer.
Strangely enough...
Russ. I'm in the shed, I'll be back in the real world in a minute.
Post #517634 Mon Feb 13 2017 3:16pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Same here from the dealer in Ascot. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #517640 Mon Feb 13 2017 3:40pm
PEACHY
What is the fault your looking to have diagnosed ? I had the same issue regarding a ARC bar leak - I said "you want to charge me �150 to diagnose a leak - I know I've got - the fluid is on my drive" - I said I will call LR assist & they can sort it for free - it worked - no charge Whistle 16MY Estoril Blue SVR.............
Post #517654 Mon Feb 13 2017 4:45pm
1014rk
Hi Peachy,
Thanks for your reply. My fault is like yours easy to diagnose. When I open my boot lid I have got a creeking noise and juddering. The left hand side damper/ actuator is about to fail. All I wanted to know was will this be covered with my warranty. I did appeal to the service lady that a technician would be able to answer my question in 2 minutes, to her credit, common sense prevailed and when I demonstrated the fault to the technician, you guessed it it was smooth and silent 😄.
I have no doubt it will return next time I open the boot.
Causeway Gray
Post #517769 Tue Feb 14 2017 2:59pm
