Home > In Car Electronics > charging a small spare battery.
pko
England 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I carry a 12v portable car jumpstart pack in the car. Not for starting the car but it has a 12v cigar socket, & tyre inflator. Question. Can I plug it into the rear cigar socket to keep it charged, & if so would it be overcharged by the car?
many thanks current 2015 hse dynamic, grey.
Post #517001 Tue Feb 07 2017 3:47pm
probably need to look at the pack instructions.
If they say you can do this, then its no problem for the RRS
Post #517009 Tue Feb 07 2017 5:28pm
pko
hi Andy. The instructions don't say. The unit came with a mains to 12v charger but I don't want to take the unit into the house to charge it. I was concerned that the power from the car 12v socket would fry the dry cell battery.
Many thanks P current 2015 hse dynamic, grey.
Post #517011 Tue Feb 07 2017 5:38pm
so you will make a lead up?
It should be ok, but the RRS likes to kick out 15V after start up apparently, which might be a bit too much for it!
Post #517013 Tue Feb 07 2017 5:54pm
pko
Hi Andy. Yes I was going to make a lead but taking on board what you say about 15v perhaps I'll have a rethink. Cheers p current 2015 hse dynamic, grey.
Post #517023 Tue Feb 07 2017 7:09pm
dalmat
Croatia 2006 Range Rover Sport TDV6 HSE Java Black
I have jump start pack too, just in case if I need it, we all know that flat battery is not unusual thing in RRS. Mine has main to 12V plug for charging and also 12V to 12V for charging in the car, both supplied with unit. It has also dry cells.
What I would do is to take the pack charger and check output voltage. In my case it is 14.4V so no problem with plunging it in the car's 12V socket
Post #517077 Wed Feb 08 2017 8:26am
pko
thanks Dalmat. You've put my mind at rest. cheers current 2015 hse dynamic, grey.
Post #517097 Wed Feb 08 2017 10:56am
