Home > In Car Electronics > WiFi hotspot
RR Ally
WiFi hotspot
There has been quite a bit of chat recently around the type of sim needed to create the WiFi hotspot. I have managed to sort this for my RRS 16 but for some reason it keeps turning off when the ignition is switched off. I then have to go back deep into the menus to turn it on again, it then stays on until the car is turned off again.
This becomes very frustrating as I use the hotspot a lot, does anyone know if there is a way of keeping this switched on all the time. Question Question
Post #516288 Mon Jan 30 2017 2:00pm
fkarim
Mine switches off occasionally but not every time the car is turned off. I haven't worked out a pattern yet. Don't know whether it depends on where the car is parked and if network is weak/unavailable it turns off.
However, data roaming does consistently switch off in mine and is super annoying when out of country and have to turn it back on every single time. Just a simple roaming warning should have been enough rather than forcing it off. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Post #516299 Mon Jan 30 2017 2:29pm
RR Ally
Thanks, i have the same issue when oversea with the roaming, but have accepted that. I have asked LR customer services for advice as well, if i get anything back i will share it
Post #516456 Wed Feb 01 2017 5:04pm
