![]() | Home > General > How many miles from a set of tyres? |
keith Member Since: 04 Aug 2005 Location: Scotland Posts: 43 ![]() ![]() ![]() |
Hi All,
RRfan Member Since: 03 Oct 2005 Location: Up North Posts: 12 ![]() ![]() |
I had a P38 RR 2.5 DT which managed 48k on first set then changed for alloys when second set were at 96k - and where still averaging 2.2mm depth - Pirelli Scorpion tyres second time.
I didn't think you get anywhere near that kind of mileage. I have the 4.4 so maybe I can budget for about 30K?
I can only go on my P38 but the wear on those was nearly even all round - meaning a large expense to replace all four at the same time! I also reckon you should replace both tyres on the same axle - not for any great technical reason as modern diffs should be able to handle the slight difference in diameters - it just seems like a more mechanically sympathetic way of doing things.
Hi Tim,
