![]() | Home > In Car Electronics > My mirrors seem to have a bit of a mind of their own |
When you go into reverse gear, they do switch themselves downward for easier reversing, perhaps triggering for some unknown reason. Can't help with cure, I'm afraid, but someone who may know will be along shortly. John
W44NNE Member Since: 30 Nov 2016 Location: North West Posts: 67 ![]() ![]() ![]() |
Yes I have that set in the settings but it was happening before I changed to that option. Currently I have the dipping mode activated on reverse, and then when I select drive or park, they go back to where they were, or somewhere close to where they were.
Wait for other replies, but often a battery reset (disconnect leads). will sort out these things, just like rebooting a computer.
Ah okay so remove the battery leads and wait several minutes? I might get the battery checked and/or replace it anyway as I'm not sure how old it is. |
Yes for leads off, I leave ten minutes, but that's me |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
To 'restart' your RRS computers you will neet to disconnect the power leads from the battery and touch them together, this purges the system.
Thanks, I actually only have one key but didn't realise what the Lazy Entry was. I was a bit confused when I saw it on the screen actually lol.
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
I have the same issue with my 2005 RRS, quite often the n/s mirror will move by itself when the car is parked up and locked. Drivers one is fine. Mirror dipping when reversing is switched off. I think it must be the module as I have recently replaced the battery and checked the alternator and its still doing it occasionally.
