Home > Faults & Fixes > Slight knock when braking at slow speeds or applying brakes
Rob199026
Hi my rrs 2006 is making a slight knock/shunt when braking at slow speeds and coming to a stop or applying the brakes quickly any help ?
Post #513978 Mon Jan 09 2017 8:12pm
Camelrock
Front lower arm sus bushes. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #513987 Mon Jan 09 2017 9:06pm
Rob199026
Oh lovely expensive job ??
Post #513988 Mon Jan 09 2017 9:14pm
Bushes can be replaced but the bolts usually seize so the arms are best just cut off. That means new arms, unfortunately, but is usually cheaper than paying a man to spend hours getting the bolts out.
Arms aren't too bad - around £300 for a pair for OEM with bolts - plus fitting time. Expect to pay c.£600 at an indie. If you go to a franchised LR dealership, expect to pay £800+.
http://www.advancedfactors.co.uk/front-low...-141-c.asp 2012 SDV6 - it's missing a couple of cylinders
Post #513996 Mon Jan 09 2017 10:14pm
Rob199026
Great !! Thanks for help going in for her mot on Monday so will probably fail !
Post #514016 Tue Jan 10 2017 7:02am
Probably won't. The bushes make a noise but still "work" so likely not to be picked up. Fingers crossed, anyway! 2012 SDV6 - it's missing a couple of cylinders
Post #514024 Tue Jan 10 2017 9:21am
