Home > Tips & Tricks > Any hints and tips for a new owner - 2005 RRS HSE |
Welcome.
Mon Jan 09 2017 5:25pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
When I got my RRS the third button on the fob was programmed to open the tailgate. I've now changed it to enable my remote fbh but presumably, even though I haven't seen it anywhere in the hand book, it is possible to have the 3rd button programmed to open the tailgate. Or is that what you have done? If so ignore me! If not I gues you'd follow the same programming procedure as for those things that are covered inn the handbook.
Mon Jan 09 2017 5:40pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Hi,
Mon Jan 09 2017 6:01pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4980 |
To program the 3rd button, you bascially hold the button down and then press the button of what you want the 3rd button to do. (i.e the boot button or rear glass) main beam flash, suspension height button.
Mon Jan 09 2017 6:19pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
If it were me I would get Bodsy round to do a top to toe on it e.g EGR blanks, remap, check EPB is set right, sort out all your "bits"....
Mon Jan 09 2017 6:24pm |
hideyspidey Member Since: 09 Jan 2017 Location: Lincoln Posts: 6 |
Thank you everybody for your help. really appreciated |
Tue Jan 10 2017 3:45pm |
W44NNE Member Since: 30 Nov 2016 Location: North West Posts: 67 |
Sorry to jump in but I like the look of this. Does it work with the standard RRS head unit (mine is also 2005)? |
Wed Jan 18 2017 11:15pm |
