Home > Faults & Fixes > Clicking noise and easing in roundabouts:
H18GYD
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Orkney Grey
Hi Everybody,
I have recently purchased a 2008 RRS-Hse and bought it under good authority that the car was really good, an upgrade on my 2007 HSE and with the same milage. WELL! where do I start? Lets just say �3k later I'm nearly there. There is one problem that has me, my machanic and my local Land Rover mechanic stumped. When driving straight my car sounds and drives fab, when going round roundabouts everything is good "mostly"BUT, every so often I get a repeated clicking noise and car seems to ease but keeps moving. Then as it starts it stops! It is not the cv joints I have been informed and nobody as yet can given me a definite diagnosis. Can anybody help me as to what my problem maybe? please. Big Cry
Dave Higgy
Post #513924 Mon Jan 09 2017 12:09pm
innox
Italy 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I was surfing the forum since i am experiencing the same noise on my MY2010 3.0 RRS
It happens to mine only when turning to the left, roundabouts or tight turns, low speed and high angle of steering (parking as well). Nothing heard from inside the cockpit (yet...i hope it will not get worse!), just with the windows open.
Glad i am not the only one...sad no one has already given any hint.
UP!
Smile
Post #524638 Thu Apr 27 2017 12:50pm
Eaters
Can you eliminate wheel bearings? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #524641 Thu Apr 27 2017 1:08pm
H18GYD
Hi ya, thank you INBOX AND EATERS.... I have spent another grand and guess what... it's still there! I have eliminated the wheel bearing EATERS... but thank you.
Post #524663 Thu Apr 27 2017 4:18pm
A ticking when turning is most likely a CV joint, to be honest.
A grand to replace a wheel bearing!! 2012 SDV6 - it's missing a couple of cylinders
Post #524683 Thu Apr 27 2017 7:33pm
One other thought - what size wheels and tyres are fitted? One wonders if it might just be something rubbing when on/near full lock. 2012 SDV6 - it's missing a couple of cylinders
Post #524684 Thu Apr 27 2017 7:34pm
H18GYD
Many thanks RRSTDV8, I am not a mechanic so I have to rely on others to do my work for me and of course this cost "lots-a-lolly" so the grand was parts labour for wheel bearing and drive shaft, if I'd have gone to my local Range Rover dealer he was quoting over �1600 plus vat! So it was quite cheap. I was informed that it is not CV joint as both sides were tested. As for the wheels they are genuine Ranger Rover wheels with Michelin tyres... I could drive it up to Northamptoshire and see a decent bloke up there and see if he knows how to find my issue!
Cheers again, it is always welcome to get some feedback.
Post #524705 Fri Apr 28 2017 12:31am
Eaters
I see you're in Surrey. If you ever travel eastwards into Sussex, then I would recommend that you consider popping in to see the guys who sorted out my issues. Groombridges in Heathfield are LR only repair garage who have been going for many years and have an in depth knowledge of these cars. Of course there's no guarantee that they can solve your issue, but if its not out of your way it would be worth a visit. Robin
Gone:
MGZTT 190 2.5
Post #524714 Fri Apr 28 2017 7:07am
Well changing the driveshaft (half shaft) is one way of checking the CV joint isn't the issue I suppose. The CV joint is part of the shaft assembly... 2012 SDV6 - it's missing a couple of cylinders
Post #524750 Fri Apr 28 2017 5:00pm
H18GYD
Many thanmks eaters. I will look in to them as it's only 50 minutes from me. Thank you very much again.
Post #524775 Fri Apr 28 2017 8:46pm
Eaters
Good. Might be worth giving them a ring first although I didn't when I first went there. I just turned up and they went straight out with me on a test drive and diagnosed my problem within 5 minutes.
And note it's not easy to find - down a lane then up a drive behind a house. But don't be put off. It might look weird but they know what they're talking about when it comes to LR. Don't expect a glossy showroom and suited and booted receptionists. Expect a greasy grumbling chap who appears to think you are disturbing his morning. Smile He's not thinkning that but you'll see what I mean. Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #524804 Sat Apr 29 2017 8:22am
H18GYD
thank you again... I look forward to letting you know my results.
Post #524886 Sat Apr 29 2017 11:48pm
