Home > Technical > IId tool code B1B68-01 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Add your engine type to your profile
Fri Jan 06 2017 6:56pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
It points to the "recirculation motor fault". I think that little motor (controls the recirculation blend flap if it's what I think it is) is on top of the blower motor unit. It appears to be accessed by removing the upper dashboard. It's below the passenger airbag so care required! 2012 SDV6 - it's missing a couple of cylinders
Fri Jan 06 2017 9:02pm |
