![]() | Home > In Car Electronics > 1.8amp permanent Battery drain problem. MY2012 RRS SDV6 HSE |
I appear to have lost the "maps" on the main Sat Nav screen. All other things Radio, DVD play all work fine. It is a HD system not DVD Maps.
Thanks Tim, will get Brother to check over the weekend, due to my disability I could get down there but not back up afterwards. |
Having to put battery on charge each night due to the the drain (see opening post) for three weeks now, (booked in early a January, evidently full).
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Call LR Assistance, they can escalate a repair at the main dealers, your will get a loan car whilst it is in, this forces them to repair ASAP. |
I did call them out when I couldn't even gain access as Battery was flat, and nothing worked. AA responded on behalf of LR Assistance, and after sometime managed to free the cover over emergency lock to gain access. (I couldn't remove it, seemed completely stuck) He put his jump leads on, from rear connection on van, plus used a 900amp battery booster to get it to turn over and start. He checked the battery which read as OK (and have had it checked independently by a local Battery distributer), the alternator output was checked and that is fine, there is no fault codes on his code reader, when everything is turned off, there is a permanent drain on the battery of 1.8-2.8 amps continuously, so he said to take it for a twenty minute run and leave on charge overnight every night until I can get it serviced. That takes sometime removing cover etc and reverse in the morning.
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
I would be seriously unhappy with how you have been treated so far regarding this Johnski. So their job is to get it running, great then get it running but if you don't have a charger too use then they will soon get fed up with visiting to start you every day or even twice a day! |
Call it in again but this time insist on a LR Tech only, they are far more responsive and will escalate it for you, accept nothing less the car isn't safe to use.. |
Call LR Assist again as the boys have said. Be polite but firm. You've "paid" for that warranty as part of the deal |
Thanks Guys I will try that tomorrow, firm but polite. |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Hello johnski
UPDATE
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I know you're still under warranty but would it be worth your peace of mind to go to an indi and get them to repair the fault ?
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
Personally, I would take it to a competent auto electrician to get it fixed. |
I think I'm now going to take it to a Indi LR specialist and Auto electricians, and let them sort it.
