![]() | Home > Off Roading & Green Laning > Owning an off-roader in the UK? |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
A bit "off topic", but will there be a replacement for the Defender????? Should have been an announcement and a few strategic leaks by now if it was going to happen!
david555 Member Since: 08 Nov 2016 Location: east Yorkshire Posts: 28 ![]() |
I looked into this, the dc100 seems to be there replacement... According to online car websites. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
LR have said 2018 for the new Defender. Expect to hear/see something next year sometime when they start running them on the roads and around the Nordschleife (because a Defender has to handle properly or something). 2012 SDV6 - it's missing a couple of cylinders
Other than width, the one thing the 90 has over the newer stuff is properly short overhangs. That can make a big difference too. Assuming you can get the nose/arse through the obstacle, the rest generally makes it look easy. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
W44NNE Member Since: 30 Nov 2016 Location: North West Posts: 67 ![]() ![]() ![]() |
Thanks for the replies. I promise if I get one, I will not just take it to Tesco! Well Aldi more likely as I'm looking at Petrol models |
