Home > General > 2011 HSE Battery - Sealed or Standard???
J2D
Thanks
John
Post #509952 Sun Nov 13 2016 1:30pm
ilard
I got his one last year:
Yuasa 12V Silver Car Battery HSB019
Dunno if it's sealed or not, and I doubt that matters by it self, but a good quality, higher performance battery makes sense for cars like ours. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #509958 Sun Nov 13 2016 1:59pm
SRE
Spain
This is what it should be
 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #509959 Sun Nov 13 2016 2:02pm
ilard
You don't need to be limited by that. My batter spec is Capacity: 100 Ah, CCA: 900A. And there are more powerful ones on the market, of course. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #509961 Sun Nov 13 2016 2:26pm
SRE
Spain
I understand the 2011 should have a glass mat battery In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #509966 Sun Nov 13 2016 3:27pm
riverblanche
Hi
AGM battery Thumbs Up
The AGM of choice is this one (it also happens to be one of the cheapest, but don't let that put you off):
Link removed Thumbs Up
Use a discount code (D2BOYS may still work) for some money off if you order from above.
If it is not AGM that comes off then may be best to change the battery charging option if you do fit an AGM
Post #509971 Sun Nov 13 2016 4:26pm
Johnski
https://www.tayna.co.uk/EK950-Exide-Start-...P9443.html Link no longer works I'm afraid. Whistle John
Post #509974 Sun Nov 13 2016 5:03pm
riverblanche
Hi,
did a copy n paste from another thread when I bought one Rolling Eyes
Post #510043 Mon Nov 14 2016 3:33pm
SRE
Spain
Don't forget BMS reset after fitting new battery, Gap IIDtool can do it, loads of info on the Disco 4 Forum. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #510045 Mon Nov 14 2016 3:54pm
Flat0ut
i bought the tanya EA1000 Exide Premium Car Battery 017TE after it was recommended on here and its been awesome
Post #510179 Wed Nov 16 2016 2:42pm
