Home > General > Another EGR valve! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
They are not hugely common, but as its a fairly involved job to replace 1 valve, it's always advisable to do them in pairs on the 3.6 (as you have found out) |
Fri Oct 21 2016 8:55pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Yep,,, I think your right, I should have used the logic that if one has failed the other can't be much better, 2010 RRS, TDV8
Sat Oct 22 2016 7:10am |
htc Member Since: 10 Jan 2016 Location: beds Posts: 15 |
I may be misinformed but I run my diesel cars on premium diesel only - I believe it minimises unwanted gunk build up. (Since I've done this my germanmobile no longer shows DPF warnings etc.)
Wed Oct 26 2016 2:33pm |
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 |
A friend of mine had his Skoda serviced along with some issue with it's EGR valve. His mechanic informed him that due to the amount and type of fouling in the valve that the car was being run on Morrisons diesel. Uncanny, as my friend and his wife only use Morrisons diesel.
Wed Oct 26 2016 9:11pm |
I may not always use premium fuel but I always use Millers diesel ecomax every time I fill up,,, this is supposed to help keep your fuel system clean so to speak. Given that the car is coming up to 92k miles and I'm quite sure this is the first time the egr valves have been changed I can't really complain. I think it's always going to be one of those parts that cause issues,,, even more so on the 2.7 version.
Thu Oct 27 2016 6:11am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
My TDV8 has been run on premium diesel for the last 5 years (c.80+k miles) and now, at 140k miles on the clock is still on its original EGRs (as far as I know).
Thu Oct 27 2016 8:43am |
