Home > In Car Electronics > Advice on where to look 1st
andywatson
Fellers,
2010 HSE RRS, normally travels 5 miles a day each way to the station and back, twice driven to work about an Hour's run on the A12.
On these occasions after about half hour there is a static sound, and the Sat Nav / Radio screen is dead - no life or sound once I stop and restart all ok for 1/2 or so.
It appears to be when things get warm? I have found that on braking hard all life returns to the system in memorised condition.
I am assuming loose wire / connection?
Any help appreciated 2008 RRS 3.6 HST - Stornaway / Black - Current
2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone
2009 RRS 3.0 SE - Sliver / Teal
Post #508180 Thu Oct 20 2016 2:49pm
Bodsy
Site Sponsor
You've double checked the battery connections? Any movement in the connections means it's either not sitting right or just not tight enoUgh. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #508223 Thu Oct 20 2016 9:57pm
andywatson
Thanks Ian, I'll look tomorrow and re-check Thumbs Up 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #508249 Fri Oct 21 2016 8:45am
