Home > General > Looking at buying a RRS tdv8 with over 100,000 on the clock |
RRSTDV8FAN Member Since: 16 Oct 2016 Location: Ayrshire Posts: 21 |
Well Guys,
Sat Oct 22 2016 8:15pm |
Hi Tim,
Sat Oct 22 2016 8:18pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
Don't panic. Most things on these cars can be fixed.
Sat Oct 22 2016 9:59pm |
Its the rear prop shaft.mainly up and down but some movement left to right. I am not much of a mechanic. Would love to be.I take it I would have to hire a ramp to get under the car. My worry is I get it up, take the old one off then get stuck fitting the replacement. Have asked gibbons autos in cumnock to have a look at it and do an overall health check on the var this Thursday. I just do not want to get stuck with a massive bill. I have not used them before so would hate to think they see it as a licence to print money.
Sun Oct 23 2016 8:45pm |
Extra inför for you. When I called Gibbons they said it might be a prop shaft bearing but that means they have to replace the whole prop-shaft. Is this correct? Give me a Mac or a pc and I will strip it down and rebuild it or install a computer network from scratch but you could tell me anything about mechanics and I am none the wiser.
Sun Oct 23 2016 8:48pm |
Agree with Phil's comments above. Don't panic - all used cars come with some issues and sorting them out helps you to make the car your own and bond with it. Probably it is the rubber supporting the prop centre bearing that has broken down and come adrift it's a common problem and most cost effective fix is to replace the whole propshaft assembly as already suggested. A simple job for a garage to do so not expensive in man hours.
Sun Oct 23 2016 9:16pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Don't panic
Wed Oct 26 2016 9:19am |
DO NOT put the car into offroad height and get under it without axle stands - it isn't unknown for the air to vent out of the suspension and you would not like 2.7t's to slowly descend onto your skull trapping you under the fully lowered car. There might be plenty of room underneath at Off-road height but at access height there isn't any............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Oct 26 2016 9:53am |
Opps, I forgot to mention that (I'm a bit paranoid about getting under any car, and always use axle stands and jacks as backup, plus spare tyres, in fact they all get in the way sometimes). |
Wed Oct 26 2016 10:40am |
Hi Guys,
Sat Nov 05 2016 10:43pm |
Forgot to say guys the plate on this car is no longer on it as it was the previous owners. ITS deceiver 2007 RRS. |
Sat Nov 05 2016 10:45pm |
You have ben given some good advice, contact Disco Mikey, you will know the work has been done correctly and that you have not been robbed.
Sun Nov 06 2016 10:18am |
I've waded through most of that list on my own RRS over the last couple of years, (the rear prop is next on my list), it's all stuff to be expected at 100K miles
Mon Nov 07 2016 7:44am |
Hi Tim,
Mon Nov 07 2016 9:53pm |
