Home > Technical > Brakes - Again!!! All round, discs, pads & sensors |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
I have replaced the brakes twice on my car (it is over 122,000miles now). The last time was about 3 years ago. I always go to my usual motor factor (Hereward car & Truck) in Stamford. The discs came in a Brembo box and the price, from memory, was similar to the Duckworth price for everything. You could call them for a price.
Thu Oct 13 2016 12:42pm |
I would take a look at advanced factors, they're a site sponsor. I usually buy from them, they do a kit with everything you need, brake sensors, new retaining bolts, copper grease, the lot really.
Thu Oct 13 2016 1:44pm |
gavwhite1972 Member Since: 23 Aug 2016 Location: Retford Posts: 33 |
Additionally...
Thu Oct 13 2016 3:02pm |
It's fairly obvious, they're only fitted to the front, the callipers are easily twice the size of the rear, painted back with Brembo in white writing facing out. |
Thu Oct 13 2016 3:14pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
I have been using Zimmerman disks and ATE pads on my TDV6.. OEM on most BMW's, They are not expensive and zink coated. very good braking power, hardly any dust and very good performance.
Thu Oct 13 2016 3:54pm |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
Be careful. I paid over 350 quid to have some non genuine discs and pads fitted. Car shook like crazy with them on. Had new LR ones fitted since by rovertune, and is a different car. I would definitely recommend the LR ones if you can. 2010 TDV8 |
Fri Oct 14 2016 6:34am |
My front callipers appear to be larger than the rear ones... all are black, none have any branding on them I can see.
Fri Oct 14 2016 8:15am |
The front callipers on most vehicles are usually bigger than the rear. It will have a fairly obvious Brembo logo written on it if it is a Brembo (unless it's been repainted), best bet would be to either google the RRS Brembo so you can see what they look like or take a pic of yours and let the internet work it's magic.
Fri Oct 14 2016 8:50am |
I suspect you are right regarding my over thinking....
Fri Oct 14 2016 9:50am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Ditto! Best price was from Dan at Duckworths and very speedy free delivery! Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Fri Oct 14 2016 10:08am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Have a look on Advanced Factors (site sponsor). They do a variety of makes. I bought Borg & Beck discs & pads from them a while ago and haven't had any problems.
Fri Oct 14 2016 5:54pm |
Does anyone know who the OEM are for the genuine LR parts? |
Fri Oct 14 2016 7:17pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
Depends on the model and year,I believe.
Sat Oct 15 2016 10:03am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
The rear discs on my 08MY TDV8 have Brembo stamped in the face of the hub. They were replaced recently following an EPB failure. Indy uses LR parts unless requested otherwise. 2012 SDV6 - it's missing a couple of cylinders
Sat Oct 15 2016 12:00pm |
