![]() | Home > Faults & Fixes > Oil pressure switch |
Sinisa Member Since: 20 Nov 2016 Location: Skopje Posts: 5 ![]() ![]() ![]() |
Is there any experiance with installing oil pressure gauge on rrs? Oil pressure light on my RRS TDV6 stays lit for 3-4 seconds when cold start. is this a sign for engine failure? on several forums I read that should change oil pump togather with timing belt set. Would that increase oil pressure on cold start? or is it only as precausion for oil pumps failure? |
