Home > Technical > handbrake problems
dave1522
handbrake problems
Hi all can any body help with a problem I have with a 2010 sport tdv8 electronic hand brake . I have code U2002-92 switch general electrical failure ??? Have fitted a new switch and cleaned and adjusted handbrake shoes . Any help would be much appreciated
Post #504212 Wed Aug 31 2016 4:00pm
If you've changed the switch then there is possibly a damaged wire between switch and EPB module by the rear axle. 2012 SDV6 - it's missing a couple of cylinders
Post #504224 Wed Aug 31 2016 5:41pm
