Home > Technical > Airbag Ecu replacement questions Range Rover sport
SH0X
Hi guys
Branching off the thread I made re passenger airbag switch fault (according to dealer level diagnostics), I have be told to consider changing the SRS ecu (located under the arm rest )
Now my questions are to anyone that has had experience of dealing with this ;
Should I buy new or can I replace with one of the same part No?
Will it need coding?
The diagnostic showed B1A00 CONTROL MODULE - INTERMITTENT
Also showed internal error control module
In addition to pass airbag switch error codes. None of which could be cleared.
Your responses would be appreciated as this seems to be very strange
Post #504092 Tue Aug 30 2016 2:47pm
SH0X
Anybody?
Post #504887 Fri Sep 09 2016 12:47am
ToteiRRs
Norway 2007 Range Rover Sport TDV6 HSE Java Black
Hi I got the same problem as you had in 2016.
Did you find out what the problem was?
Any tips and tricks?
Post #593778 Fri Jan 24 2020 1:20pm
Red Arrow
I had the same issue and it turned out to be the wiring under the seat Thumbs Up
Post #593785 Fri Jan 24 2020 6:43pm
