Home > Technical > aircon condenser change
steve.rrs
anyone know the easiest way to fit a new aircon condenser on a 2005 rrs 4.2sc
steve
Post #503976 Mon Aug 29 2016 3:17pm
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
pulling this back up as I am about to do this Tuesday.
Post #505110 Sun Sep 11 2016 7:17pm
Paddi
There are quite a few threads on this. just type condenser into the search box.
Here's one for starters:
http://www.rrsport.co.uk/forum/topic36854....=condenser
Don't ask me for any tips though - as I haven't had to replace mine yet thank God! 2008 MY Java Black TDV8 HSE
Post #505182 Mon Sep 12 2016 4:29pm
Rasher 007
Hi fella, me and "ragpicker" went through this on another
Post under tdv8 condenser change. This covers the 2007
Rr sport and you'll see by pictures if it is the same as yours
Good luck, hope it helps If a hammer won't fix it.... It's electrical!!
Post #505185 Mon Sep 12 2016 4:31pm
Cpt Jack Sparrow
cheers
did a few searches and could not find the answer I was looking for, so tonight I have stripped back to the slam panel, which now has two bolts soaking as they just won't budge. Confused
hopefully they will release in the morning Bow down
Post #505207 Mon Sep 12 2016 7:37pm
Rasher 007
Yeah!!! They are tight!! Think I snapped 2 of mine but not
Hardened so easy to drill out, just a pain. Lots of copper grease
When re fitting. I dunno how to send link but it was under
Technical as " help required! Tdv8 A/c condenser removal"
There you should find it or look in my gallery and see if plcs are
There If a hammer won't fix it.... It's electrical!!
Post #505215 Mon Sep 12 2016 8:39pm
Cpt Jack Sparrow
yeah, I found it thanks
Post #505220 Mon Sep 12 2016 9:10pm
Cpt Jack Sparrow
job done, only one bolt had to be cut out.
Cold dry air again Mr. Green Mr. Green Mr. Green
Post #505362 Tue Sep 13 2016 9:25pm
