Home > General > Oil for 3.0 TDV6 |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
My book of words says WSS-M2C934-B spec, it's a 2011 TDV6 3.0 lump...
Sun Aug 21 2016 6:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Landrover seam to recommend Shell Helix 5W30
Sun Aug 21 2016 7:23pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Ok this seems to be a fault!
Mon Aug 22 2016 3:00pm |
hodjie Member Since: 13 Nov 2013 Location: United Kingdom Posts: 91 |
without sounding stupid have you warmed it up then switched it off for 10 minutes then checked it again ? i thought the same thing when i first got mine |
Tue Aug 23 2016 8:49pm |
Yeah, fully warmed up and check after 10 minutes as per handbook, still below min with no warnings at any point. I'll let the dealer look into it when I'm back home. |
Wed Aug 24 2016 12:56pm |
These things really could do with a 'manual' dipstick on them as well, you can't even tell the colour of the oil without!
Wed Aug 24 2016 5:28pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Is this possibly the gear box filler tube? I seem to remember I was told not for oil on L320 model. I also much prefer to have a proper dipstick, don't trust these electric readout ones at all, and you have absolutely no idea of quality of oil etc without one. A stupid design decision. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Wed Aug 24 2016 6:00pm |
I know, digital readout is nice, but at least have a back up dipstick!
Wed Aug 24 2016 6:06pm |
It's a diesel. The oil will be black |
Wed Aug 24 2016 6:23pm |
I'm not sure that you would like the old style dipstick that the 2.7 had, stupid piece of wire with yellow plastic beads on it that was neigh on impossible to read. My Defender has the best one I've had lrecently, the old style flexi flat thing with notches for min and max............ Simple and easy to read. Both the Evoques I owned both had proper dipsticks too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Aug 24 2016 7:07pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
[quoteThere is a tube that looks like a dipstick tube, however, comes up on the front left corner of the engine block (as you're facing it) and has a latched cap on it (like a BNC connector) with an O ring. Not sure if it's the redundant dipstick tube or not...[/quote]
Wed Aug 24 2016 7:19pm |
I've seen worse! Like a black plastic dip stick end. And your trying to work out where the oil is |
Wed Aug 24 2016 8:03pm |
