Home > Tips & Tricks > Electric windows
Rob876
England 2010 Range Rover Sport TDV8 HSE Bali Blue
Electric windows
I'm new to this site and appologise if this has already been dealt with.
Should my windows go up automatically? (2010 TDV8) At the moment I have to hold onto the switch until the windows are completely closed. Can this be rectified?
Thanks in anticipation
Post #503245 Fri Aug 19 2016 8:23pm
Sounds like they simply want resetting.
Operate window, when fully closed release switch then operate switch again and hold in closed position for few seconds, do same on all window and they should reset.
Post #503248 Fri Aug 19 2016 9:57pm
Rob876
Thanks Col - I'll give that a try - Rob
Post #503250 Fri Aug 19 2016 10:12pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
You're lucky you have one touch open/close on all windows. On the pre-facelift its only the drivers window, the rest you have to press and hold Censored 2006 Java Black HST Supercharged
Post #507667 Wed Oct 12 2016 7:35pm
jatin22aug
Thanks
Post #571952 Sat Dec 29 2018 9:30pm
