Home > General > TDV8 leaking coolant
Brad83091
Ireland 2006 Range Rover Sport TDV6 HSE Luxury Java Black
hello all
I have a 07 V8 mileage is high 280km
the last 2 months I have being getting errors on screen "check coolant level" I was always topping it up by a litre or so of water.
I got sick of topping it up I went to my local independent garage and we changed the coolant bottle, new sensor, and did a coolant flush. also he pressure tested the system after changing the bottle and the pressure held steady... he commented the engine is not giving any signs of head gasket failure..
Now my top ups are more frequent eg every 2 days with no trace or drips being detected...
Any help or opinions will be greatly appreciated
Post #502964 Tue Aug 16 2016 1:06pm
Paddi
Did the new coolant bottle come with a new cap? A faulty cap can cause what you describe. The pressure test won't show it up because the cap is removed and the pressure tester takes it's place during the test. 2008 MY Java Black TDV8 HSE
Post #502968 Tue Aug 16 2016 2:49pm
Olly-ibiza
Thermostat housing in the middle of the V at the front, quite common for leaks spiteful Range Rover Sport tdv8
Post #503012 Tue Aug 16 2016 10:26pm
Brad83091
No. The old one was reused
Post #503014 Tue Aug 16 2016 10:49pm
Brad83091
Cheers. Is there much dismantling to examine that
Post #503015 Tue Aug 16 2016 10:50pm
