![]() | Home > Detailing & Car Cleaning > foundry satin grey stained? |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
I had that on my door handles, couldn't get it off, colour coded the handles in the end spiteful Range Rover Sport tdv8 |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 ![]() ![]() ![]() |
Thanks thats what i thought. I have tried several products to try and remove the stainlng but none have worked so it looks like they will have to be repainted |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
I beleive the is a type of chemical discoloration but no clue as to what chemicals caused it. I have the same discoloration on the front fascia around the grill. There's really no way to get it out without repainting or some sort of cover up. My best guess is it may be caused by salt collected during the winter mixing with the soaps from the touchless car wash since the soaps they use can be pretty aggressive.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Is this of any help?
That sounds like snake oil to me. Traffic film by the definition given in the link you posted can all be removed with a clay bar and if need be, dish soap to trip the wax and sealant layers to start fresh with what some people call "naked paint". then you do a light coat of cleaner wax and re-seal. As for the plastic trim... Short of some sort of abrasive, that stuff will not come out. Pretty sure re-painting is the only alternative. |
