![]() | Home > Maintenance & Modifications > DAsh creaking |
Jimbob36 Member Since: 13 May 2016 Location: Melton mowbray Posts: 74 ![]() ![]() ![]() |
Wrap some insulating tape around the pivot pins! Amazed the problem still exists! |
Goffie01 Member Since: 19 Nov 2013 Location: Shropshire Posts: 20 ![]() ![]() ![]() |
Cheers. What do you mean by pivot pins (Hinge Pins) ? Maybe. |
Yep. I'm still trying to work out how to stop the upper opening boot section rattling! If I wind out the buffers too much it puts a lot of pressure on it. |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
When I took delivery of my new 2010TDV8 back in Dec. 2010 it a bad rattle/squeek from the rear hatch area. After some investigation I found that the left hand side of the glass hatch was touching bodywork in the closed position (badly aligned from the factory). I mentioned it to my dealer and they simply wound out the rubber buffers to fix the problem - which was not a fix as the hatch became very hard to close and the hatch edge was raised above the rest of the body work.
