Home > General (L494) > Noise from Pillar
DangerMouseUK
United Kingdom 2013 Range Rover Sport Supercharged Santorini Black
Noise from Pillar
Has anyone else had a noise coming from inside this pillar ?
No amount of fiddling with it on the outside will make it stop !
Post #501614 Mon Jul 25 2016 2:41pm
AJ1
Australia
Well that all depends on your interpretation of the word "noise". Is it a squeak, rumble, knock, continuous or intermittent ?
I recently had a ticking sound from this area and discovered it was actually coming from outside after heat expansion being in direct sun. And found a fix for it. Happy to help if you have the same one. MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's.
Post #501669 Tue Jul 26 2016 4:34am
Lyonhead
Wales
Yes, I have a "noise " coming from there also. The car is in with the dealership now. It's like a very light metallic tapping sound but not continuous, intermittent and very distracting as its right by the side of your right ear as your driving.
But, the car is also in for brake squeal, rear compartment rattle, Sat Nav traffic warning not working. I've managed to do a 1000 miles with the car from new, delivery was April 30th 2016 and I would say a lot of that has been done back and forth to the dealership and them test driving!!!!! Big Cry Big Cry Big Cry
Post #501671 Tue Jul 26 2016 6:23am
AJ1
Australia
The dealer won't find the fault. I have the fix. It bugged me so much I stripped everything down and found it. Let me know how you get on with the stealer and if you need help. MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's.
Post #501672 Tue Jul 26 2016 6:29am
Lyonhead
Wales
AJ1, I would appreciate if you could just let us know how you got rid of this in case, as you say, the dealer won't be able to find it..... Every little helps.
Post #501673 Tue Jul 26 2016 6:34am
AJ1
Australia
The problem lies with the outer black door pillar skin. It expands in the heat and contracts as it cools thus creating a ticking sound. Annoyingly right next to your ear.
Once the offending part has been identified, it's a simple fix.
I inserted two wooden meat skewers straight down the tiny gap. Gently tap them home with a hammer until they're fully inserted. You'll need to pull away the rubber from the top corner of the door, then pop it back in once the skewers are all the way down.
I know it sounds a little rough, but it works ! (Photos attached)
You could use anything of similar dimensions if you don't have what I used.
Good look.
Andy MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's.
Post #501674 Tue Jul 26 2016 6:52am
Lyonhead
Wales
Good man, thanks for that. ( pics didn't come through though).
I'll pass on the details to the dealership when/if Shocked the car is returned and the noise is still there Smile
Post #501675 Tue Jul 26 2016 6:59am
Lyonhead
Wales
Just got pics, thanks very much Bow down Bow down Bow down
Post #501676 Tue Jul 26 2016 7:00am
rangiejools
Australia
Thanks Andy, I'll be trying that fix too....got the same ticking sound sometimes.
Jools RRS P460e
1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired.
Many big trips done in this one.
1982 Rangerover nearly restored.
22 Defender D250 with lots of stuff for outback touring
Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad!
2013 Land Rover Defender ute.
Post #501745 Wed Jul 27 2016 3:27am
AJ1
Australia
Let us know how you go with it Jools, glad to be of help.
Andy. MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's.
Post #501746 Wed Jul 27 2016 3:41am
Lyonhead
Wales
Andy, just got my car back from dealership and your fix did not sort the noise out Crying or Very sad BUT the dealership put a technical request into LR and the resultant work has now sorted out the noise.
LR technical advised lubricating the inside of the pillar with a spray lubrication Question And after an extensive test drive by myself and the dealership representative there is now NO noise Thumbs Up Thumbs Up
I have been told that a small number have been advised to do this and none have come back with the noise returned.
Now I can start to enjoy driving my car without the annoying tapping noise by my right ear.
Thanks for all your help though Bow down Bow down and hopefully this may help others who have a similar problem and if your fix does not help then this will. Very Happy
Post #502078 Wed Aug 03 2016 3:02pm
AJ1
Australia
You're welcome Lyonhead.
As I said, once the offending part has been identified, it really is a simple fix.
My meat skewers worked for me, but I'm sure someone will come up with an alternative, however don't hold your breath with that wd40 the main stealer has squirted down there..... It's gotta run out somewhere, no doubt all over your lower door skin and the noise returns.
In the meantime, enjoy it while you can.
Post #502115 Wed Aug 03 2016 10:52pm
scott2k21
Was this a kind of creaking noise that seemed to come with body flex (not necessarily bumpy roads giving a rattle) ...and worse on warmer days??
I have a noise that seems to be coming from across the passenger side somewhere ...dealer couldn't replicate (shock!) but continued to remove the air vent to lubricate plastic parts anyway (and in doing so managed to leave the dash panel unclipped)
Needless to say even after fixing the dash it's still there and is noticeably worse on warmer days ...kinda thankful we're heading into the colder months because of it Rolling Eyes
Post #505629 Fri Sep 16 2016 7:09pm
AJ1
Australia
Not really Scott, more so a "ticking" whether the car was moving or not. However you're correct with warmer days which tells me it's 100% expansion. Also mine was on the drivers side (could still be the same part).
I doubt the dealer can identify it if you can't. As I've previously stated - once the offending part I'd found, it's a simple fix. Only hours of tedious listening will reveal its cause, most definitely a job for the owner unfortunately.
Good luck,
Post #505653 Fri Sep 16 2016 10:26pm
BlackGT3
We had a rattle noise coming from both side by the upper front seat belt mounting. This was supposed to be fixed during last years service however, the rattle returned. Dealer (Farnell Guiseley) told me that LR had issued a new part which fixes the problem. This was ordered and fitted and the rattle has been fixed. Current:
2014 RRS HSE - Causeway Grey, Ebony with Ivory seats, Ebony roof lining, Black Piano wood, Panoramic Roof, Heated Exterior Mirrors, Heated Steering Wheel, Privacy Glass, 21" Wheels, Electric Tow Bar, Full Size Spare, Load through & Black Badges. 5 yr service pack
997 GT3
Golf R DSG
Past
2010 Discovery 4 HSE
2006 Discovery 3 HSE
Post #508033 Tue Oct 18 2016 12:45pm
