Home > General > Playing radio with engine off
srkamath
I have just picked up a 62 Reg RRS and a newbie to this vehicle. I am planning to go for an outdoor drive-in cinema and am told that the audio for the movie would be played through a FM channel. I am worried that if i am going to switch my engine off and play the radio to watch the movie the battery may drain out since am looking at around 2 hours of radio playing with the engine off. Is it possible that the battery could drain out if I play the radio for so long ? Is there any other alternative ?
Need advise since based on the response i would like to think about going for the movie.
Post #499912 Thu Jun 30 2016 11:23am
ABSport
The battery will drain very quick I'm afraid. I had the radio playing on mine for 45 mins once and could not start the car !!! In the end I replaced the battery. Shocked
Post #499913 Thu Jun 30 2016 11:35am
Tim in Scotland
Better to take a portable FM radio with you - then you only flatten some C or D cell batteries and not the car's battery. On more recent cars you only get 10 minutes radio use before it closes down............... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #499914 Thu Jun 30 2016 11:48am
srkamath
Thanks...thinking a portable radio may not give a good audio experience. Additionally I need to buy one as well.
Another option is to let the engine run , which is not ideal however thats an option. Any advise on this option ?
Post #499991 Fri Jul 01 2016 9:41am
It's very sad you can't listen to it though your premium radio.
Take a different car to the movie ?
Post #499993 Fri Jul 01 2016 10:41am
Ianm
United Kingdom 2012 Range Rover Sport SDV6 HSE Stornoway Grey
I'm (obviously) no expert, but I wouldn't have thought the radio would draw that amount of current to drain the battery in such a short time. From memory following a couple of hours drive (when you would expect the battery to be fully charged) car shut down radio after only 10 mins showing something like "low battery"
Post #500031 Sat Jul 02 2016 6:35am
I guess the big amp doesn't help.
And powering up many systems and displays.
Post #500034 Sat Jul 02 2016 8:03am
srkamath
Unfortunately I don't have a second car. Moreover the idea of drive in cinema was to enjoy it with the RRS Smile
Post #500041 Sat Jul 02 2016 10:16am
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
I think LR being over cautious with the radio running time, as Tim mentioned mine only gives 10min before it shuts down, while audio system could draw lot of power if its running at high volume it's not the same with low volume as many would do.
Post #500043 Sat Jul 02 2016 11:34am
A couple of hours driving won't necessarily fully charge the battery in these cars. 2012 SDV6 - it's missing a couple of cylinders
Post #500044 Sat Jul 02 2016 12:02pm
For what it's worth, I think the 10 mins thing is only when the key is out (RRS1).
I also notice the volume is limited to 20? when the engine is off. A further attempt to prevent power drain.
They have implement some stuff !
Post #500046 Sat Jul 02 2016 12:19pm
garrycol
Australia
Turn the key to "accessory" and the radio will stay on for as long as you want. With the key in the ignition but in the off position the radio only stays on for 10 minutes.
When my battery was good (it is not at the moment) the radio could be on at moderate volume for a couple of hours before there was an issue.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #500048 Sat Jul 02 2016 1:40pm
The OP has a 62 plate car which has keyless entry and pushbutton start, they do not have a "accessory" position as such and it all shuts down after around 10/15 minutes or at least mine does whether using Radio or TV etc.
Post #500049 Sat Jul 02 2016 1:53pm
SH0X
Consider buying a Ctek charger to keep your batteries at top form.
Moving your seat back and forth before entering the key is something you should try to avoid doing too as it uses alot of the battery over time. Ctek is great if the car does alot of short trips and battery doesnt get a full charge.
I bought one after being advised to on the Mercedes forums when I had my SL500 - THat used two batteries and it was an essential bit of kit to have !
Oh and cant you monitor the battery rate on the built in screen on the car?
Maybe keep a booster pack with you - again a good thing to have !
Post #500057 Sat Jul 02 2016 5:59pm
