Home > Faults & Fixes > Amber Park brake light |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
You don't say what model/year but.....The only thought that I had is that as yellow is a warning, get the codes checked (if you have something like the IID BT Tool no problems), could even be the battery, but may be needing "adjustment"
Sun Jun 05 2016 8:42pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9010 |
May need the shoes adjusting or replacing. Might be a brake switch issue. Did it refuse to release when you tried to drive away or did you use the park brake switch to disengage (with foot on brake pedal)? 2012 SDV6 - it's missing a couple of cylinders
Sun Jun 05 2016 8:50pm |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 |
Yes it would not let me move out of park. Until I switched engine off and back on again. |
Sun Jun 05 2016 9:08pm |
