Home > General > Poltergeist type experience driving.
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Nice driving with the Sport, but the time has come to see it go.
Post #497690 Fri Jun 03 2016 9:17am
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
First things first
Fuses - Try pulling out and re-inserting the fuses one by one. Technically this should NOT help but I did it once for a similar issue and it fixed the problem so you never know... Also, it's FREE
Battery - Check the connections for corrosion, wear etc. Try disconnecting the battery for 5 mins to reset the ECU. While disconnected lube it up with electrically conductive grease
Ground leads - Check the ground leads to the battery. Disconnect them and do the same as for battery WHILE the battery is disconnected. DO NOT TRY THIS WHEN THE BATTERY IS CONNECTED!!!!!
Basically the idea behind this is to eliminate the simple easy stuff that you can do at home so when you go to the dealership you can say you did all that and give them less work to do, hence a lower repair bill for you.
Very Happy
Post #497707 Fri Jun 03 2016 1:46pm
Battery
Alternator
Brake light bulbs
Brake switch
Earth connections
The usual litany of things to check. 2012 SDV6 - it's missing a couple of cylinders
Post #497727 Fri Jun 03 2016 6:09pm
RonyTed
England 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Hi, this is all down to battery state of charge/alternator, had same with my '06 s/c, if your battery is on its last legs (not always diagnosed by voltage reading or high discharge test) it will overload and cook the alternator trying to both charge and keep all the electrical systems running. on the safe side I replaced both battery and alternator resulting in all problems solved.
cheers,
Tony.
Post #497760 Fri Jun 03 2016 9:32pm
designboy
Hi guys sorry for the late reply I've had a terrible few days! So the update on the sport is I dropped it in on Friday after the same fault presenting itself in the same sequence - locks - suspension - turn off sat navigation- disable indicators and leaves hazzards on. When I turn off the car it won't turn on again for 3 mins or so. But then drives as normal.
I'd read your advice and I'll pass that onto the 4x4 specialists I have it with in Belfast. The owner of the garage worked on it himself for me over the weekend and said that he reckons the can bus is the fault. Basically it's thrown up codes all over and he has recommended to swap out my instrument panel.
I think the good news is that the suspension etc all work it's just the computer is messing up. One thing I remember doing is plugging my smart watch into a cigarette charger it's a fast charge device and it may be concidiencial or the electrical gremlin.
Really hoping it gets fixed easily!
Post #497989 Mon Jun 06 2016 2:18pm
CANROVER
Ground leads play a super huge factor in electrical problems. I learned this lesson a few months back when I had a delayed start issue. The dealership replaced the fuel pump, filter and a few other things and still nothing. In the end it was a decayed ground strap so before you spend THOUSANDS, get the tech to check ALL the ground leads and make sure they are intact and in good condition. Spend small before you spend huge.
Post #498022 Mon Jun 06 2016 8:32pm
designboy
Thanks all, I've a little spark of hope that I may get this resolved with a little checking.
Post #498121 Tue Jun 07 2016 3:50pm
designboy
Sadly after a lot of tests from my indies, they asked me to try the main Land Rover garage here in Belfast to see if they can get any thing other than what they suspect is the main issue - the instrument panel.
They done me a massive favour trying out sensors, running tests and testing the ECU.
They even went ahead and emailed me the fault codes - Take a look at these for codes!
Vehicle scanned on 05-06-2016 20:15
Using IIDTool Pro V3.0 B2763
Active Roll Control
C1B11-62 (6Cool Pressure control valve - Algorithm based failure - signal compare failure
( on 04-06-2016 09:58:09 at 221194 km )
U0155-87 (AF) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
( on 05-06-2016 20:13:12 at 221198 km )
Body Control
U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
( on 04-06-2016 10:21:48 at 221190 km )
HeadLight
U3000-55 (6Cool Control module - System programming failure - is not configured
( on 05-12-2020 21:14:05 at 221198 km )
Instrument Pack
U0159-87 (2C) Lost communication with parking assist control module - Bus signal/message failure - missing a message
Parking Aid
B1B57-11 (2F) Front sensors power circuit - General electrical failure - circuit short to ground
B1B58-11 (2F) Rear sensors power circuit - General electrical failure - circuit short to ground
U0155-87 (6C) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
U0140-87 (6C) Lost communication with body control module - Bus signal/message failure - missing a message
U0300-55 (6C) Internal control module software incompatibility - System programming failure - is not configured
Parking Brake
U0101-87 (ACool Lost communication with transmission control module - Bus signal/message failure - missing a message
( on 05-06-2016 20:14:44 at 221198 km )
Steering Angle
U0122-87 (6C) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
( on 05-06-2016 20:13:16 at 221198 km )
Transfer Case
U0155-87 (2E) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
Transmission
( on 05-06-2016 20:13:08 at 221198 km )
Vehicle Dynamic
U0155-87 (2B) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
( on 05-06-2016 20:13:10 at 221198 km )
Ventilation
B1B74-00 (2C) Front foot-defrost mode stepper actuator
( on 04-06-2016 09:52:45 at 221192 km )
B1B75-00 (6C) Front foot-face mode stepper actuator
B1B76-00 (6C) Front left air blend stepper actuator
B1B77-00 (6C) Front right air blend stepper actuator
B1B78-84 (2F) System pressure - Bus signal/message failure - signal is below allowable range
( on 04-06-2016 09:49:58 at 221192 km )
Vehicle scanned on 04-06-2016 10:00
Active Roll Control
C1B11-62 (AF) Pressure control valve - Algorithm based failure - signal compare failure
( on 04-06-2016 09:57:03 at 221194 km )
Parking Aid
Ventilation
B1B74-00 (2F) Front foot-defrost mode stepper actuator
( on 04-06-2016 09:51:39 at 221192 km )
B1B75-00 (2F) Front foot-face mode stepper actuator
B1B76-00 (2F) Front left air blend stepper actuator
B1B77-00 (2F) Front right air blend stepper actuator
( on 04-06-2016 09:48:52 at 221192 km )
Active Roll Control
Body Control
HeadLight
Instrument Pack
Parking Aid
Parking Brake
Steering Angle
Transfer Case
Transmission
Vehicle Dynamic
Ventilation
Post #498807 Thu Jun 16 2016 4:22pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
You must hold the record for the most recorded faults. Big Cry
What did they recommend to fix that lot then.
Hope it is just a bad earth somewhere Wink Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #498849 Fri Jun 17 2016 6:35am
designboy
Thanks. There is always a silver lining! I've now it going to the main land rover dealers here in Belfast. So hopefully they can spot what needs sorted on it. The indies are thinking it's the instrument panel needs replaced but think I'm best getting a second opinion. I appreciated them doing that and not just fitting it in hope. So fingers crossed. Shame as I really miss driving it.
Here are the pics it gives on dash...
Post #498897 Fri Jun 17 2016 7:48pm
Cammy72
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
body control module?
Post #498931 Sat Jun 18 2016 11:11am
designboy
Okay little update. Might be a glimmer of hope. I tried my spare key last night and drove for around 25 minutes (15 more than usual) and it went without any fault right to the door. I'm going to try it again today but would a key make a difference?
Post #499018 Sun Jun 19 2016 1:26pm
designboy
SORTED THE PROBLEM!!
It took a long while, but to help others, it was the instrument panel. Coupled with the ARB bars leaking, so a few pounds lighter and the car working once again. The instrument panel is 700 quid, so its not a cheap one to replace, I think the v8 version I have costs more than the v6?
Hope this helps anyone else with these issues.
Post #501998 Tue Aug 02 2016 12:11pm
Johnski
So glad you got this sorted, the Independant dealer weren't far wrong in the end. It's a shame you can't fit secondhand/used displays, but that's the disadvantage of all the electrics, everything has to match, and all the mileage etc wouldn't match I believe, from a LR mechanic. John
Post #502049 Tue Aug 02 2016 11:30pm
