Home > General > Drivers door not locking!??
J2D
Having a few issues when locking our 2011 RRS HSE, normally I double tap the lock button on the remote to double lock it, the indicators flash twice (longer on the second flash) car locks and mirrors fold in.
But over the last few days it has been locking, but the mirrors don't fold in and the indicators don't flash, sometimes it will also make a small single bleep, and or the alarm will go off!
Any ideas what the problem could be??
John
Post #496349 Tue May 17 2016 7:48pm
HemoRRS
The beep means one of the doors, boot or bonnet are open. When you lock it and it beeps walk round the car to see which one isn't locked.
Do you get any bonnet open messages at all?
Post #496360 Tue May 17 2016 8:45pm
J2D
I have worked out the problem, it's with the drivers door, the chrome latch by the handle (pic below) is stuck, when I press the lock button it doesn't move (stays open) and it's really stiff to push
Anyone had this problem? Any solutions?
Would this issue be covered under my 2 year RR warranty ?
Post #496444 Wed May 18 2016 7:07pm
Bodsy
Site Sponsor
sounds like the actuator wire or actuator itself has failed and not in the usual way
I would have thought it would be covered by the LR warranty (I assume you bought as approved used from LR Dealer) Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #496445 Wed May 18 2016 7:46pm
ABSport
If it's the just the cable it's a cheap part to replace around £15, however to get it to fit to both ends the other end is connected to your door latch which is not a easy job to remove.
Window motor has to be removed along with door window and then the latch removed to Unclip the cable Big Cry
Post #496452 Wed May 18 2016 8:20pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Am I correct that by pressing a door lock button it should respond with a bleep or chime?
Mine (MY12) doesn't make any sounds other than the solenoid noise.
How can I enable the chiming? RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #496536 Thu May 19 2016 6:47pm
gogsy1956
Mine does not chime when locked also, but do get a double beep if a door etc is not closed properly. I am sure I read an article on here the other day saying that a chime can be programmed when the car is locked,, maybe Bodsey is your man to ask. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #496543 Thu May 19 2016 7:23pm
J2D
Whilst in for a service yesterday, I mentioned the problem I was having with the drivers door lock, they think it's a wiring fault, they want to charge me £60 to find out exactly what it is, and if it is what they think (wiring fault) it WON'T be covered under my approved used warranty! Where as if it turns out to be a component all costs will be covered!
He did say if it is a wiring fault he will speak to LR and try and get a 'good will' gesture, as it's always been serviced at a main dealer!
Pretty disappointed to say the least, I was told if I had any problems the warranty work cover it!
Anyone else had this problem?
Post #497323 Sun May 29 2016 9:07pm
I reckon it's the actuator as it sounds similar to a problem I had. Typical LR dealership response - I think they try to scare people off so that they can just do the high-profit servicing. 2012 SDV6 - it's missing a couple of cylinders
Post #497327 Sun May 29 2016 9:44pm
Dhups
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Got the same issue with mine - double beeps when you press the lock button.
I'll have a look at the driver lock latch to see if it that issue.
Don't have full LR warranty so will have to try it under my RAC one Shocked
Post #500579 Mon Jul 11 2016 1:01pm
J2D
UPDATE
Took the RRS in to Land Rover Saturday, it was in 3 days, whilst I had a brand new discovery as a courtesy car
It ended up needed a new door lock, actuator and mirror motor!! And was all covered under the LR warranty! Didn't cost me a penny. Happy days!
Definitely worth paying the extra and buying from a main dealer 👍👍
Post #500617 Mon Jul 11 2016 8:43pm
