Home > Technical > suspension question |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
I think it only alters the height if is more than 10cm out. |
Mon May 02 2016 5:24pm |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
Do you get any red flashing lights above the wheels on the 4x4 info screen when you lower it? I had the same problem when one of my ride height sensors was dead. Drivers side front was sat higher than the rest. |
Mon May 02 2016 5:25pm |
piedjie Member Since: 18 Apr 2016 Location: Menen Posts: 12 |
everything seems fine on the screen, no red lights. The car drives very uncomfortable though. When I raise the car and lower it again it drives better. Compressor problem? |
Mon May 02 2016 5:37pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Probably not. If the suspension is going up and down on command, and no warnings appear on the dash after a minute or two, then you can probably safely assume that the compressor is running ok. Much more likely to be a height sensor. Possibly need to get it plugged into some diagnostics to check. Actually re-reading your original post, it could be that your air springs are leaking. Keep checking if it drops overnight on the same corners. |
Tue May 03 2016 7:06am |
Definitely sounds like a sensor to me. When my sensor was replaced they also replaced the compressor as I would get the 'suspension raising slowly' message after dropping/raising a couple of times. If you also see that message it might be a combo of both? Get it plugged in, the sensors are pretty cheap. If there are no warnings it might just need recalibrating. |
Tue May 03 2016 7:55am |
so today I did the same thing: suspension up and down. Got out and measured: again 47,5 perfect on each corner. I think the sensor are ok.I must have a leak somewhere. Better leave it to a dealer I guess. |
Tue May 03 2016 6:41pm |
