Home > Faults & Fixes > ACE
Brutus
England 2006 Range Rover Sport TDV6 Autobiography Java Black
ACE
How would I know if I have ACE (assisted cornering enhancement) fitted to my car? Trying to buy a belt and apparently, they are a different length if fitted.
Post #494391 Mon Apr 25 2016 12:05pm
Disco_Mikey
If you have ACE, you will have Brembo front brakes fitted as standard, and an additional fluid reservoir clipped onto the airbox, and a valve block fitted underneath the OS B pillar Thumbs Up
Post #494392 Mon Apr 25 2016 12:06pm
Camelrock
As I understand it, it's only fitted to S/C and TDV8's though it might be an optional extra on TDV6 cars, but quickest way to check is under the bonnet at the front of the engine there will be a reservoir with a yellow cap, not the PAS which Lookes the same, or look under the car on the drivers side on the chassis rail you will see a valve block with about 6 pipes connected to it.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #494393 Mon Apr 25 2016 12:13pm
Gornal Hills
That's an interesting point lads, i have a 2.7 v6 with ACE and brembo brakes. I am left wondering what is standard and what's been added as i have SNOTM, three flash indicators, clock on the dash and lights on (green) ?? Is this standard issue or has it been tweeked ? Would be nice to know if the dredded EGR's are blanked Whistle 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #494395 Mon Apr 25 2016 12:49pm
Brutus
Many thanks Disco Mikey & Camelrock. I'll check it out later.
Post #494397 Mon Apr 25 2016 12:57pm
Disco_Mikey
The V6 came with ACE and Brembo's as part of the DR pack
All pre-07 V6's (IIRC) came without DR, and most 07-09 V6's came WITH DR
There will be the odd exception, but in general Thumbs Up
Post #494399 Mon Apr 25 2016 1:30pm
Gornal Hills
Cheers Mikey, now i'll be thick and ask what the DR pack was, is.. Embarassed 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #494401 Mon Apr 25 2016 2:45pm
Disco_Mikey
Dynamic Response
Essentially, 20" wheels, ARC, Brembo's, bigger rear brakes
Post #494405 Mon Apr 25 2016 3:06pm
Gornal Hills
Cheers mate, thanks for educating me Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #494408 Mon Apr 25 2016 3:13pm
Tim in Scotland
DR pack also included the updated steering rack that allowed the owner to fit up to 20" wheels without the owner (or LR) busting the warranty...... It became standard for 2007MY on all RRS's IIRC 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #494419 Mon Apr 25 2016 5:23pm
Disco_Mikey
I have worked on a few 08/09MY's without DR, but they have all been low spec cars
It may have been standard from 07 on all HSE models Question
Post #494423 Mon Apr 25 2016 6:36pm
