Home > General (L494) > Terrible squeaking that sounds like a banshee
Humbug
My MY2014 HSE has developed terrible squeaking when under 30mph. Seems to be most common when reacting to a bump, especially with any steering input. Over 30mph it disappears completely.
At first perished anti-roll bar bushes were diagnosed but changing these made no difference. I'm now awaiting return visit to the dealer and the squeaking is louder and more shrill than ever. To me sounds like it's coming from further back. At first I was sure it was to do with the suspension but recently I've been thinking about the gearbox/transfer box mounts, but have no idea if they're rubber or solid.
Grateful for any ideas.
Post #494332 Sun Apr 24 2016 1:35pm
wilf
Stone trapped against a brake disc?
Is it continuous, or on/off with suspension movement? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #494335 Sun Apr 24 2016 1:54pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Another one for a stone, removed the wheels and have a look, is it comming from any side or front or back ? Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #494343 Sun Apr 24 2016 3:49pm
Humbug
No, definitely not a stone.
Loud screech most noticeable when suspension returns and settles after movement, especially when combined with steering input, but only up to 30mph. It sounds closest to a horror film creaking door – so loud that pedestrians jump from the noise as I go over speed bumps. Both I and dealer assumed it was perished rubber (so the anti-roll bar mounts) but changing these made no difference. At first sounded like coming from the front, no particular side, but lately it feels further back so wondering about drivetrain/gearbox/transfer box mounts but this seems very unlikely.
Can't think what else could make such a noise so any other ideas very welcome.
Post #494344 Sun Apr 24 2016 4:57pm
Tim in Scotland
Have you had the EPB pads replaced recently? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #494345 Sun Apr 24 2016 5:12pm
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Possible air suspension issue? I think you're car is off road quite a bit, and the issue disappears over 30mph, so maybe the compressor is having a problem....or leaking air suspension?
Post #494346 Sun Apr 24 2016 5:40pm
never ready
Mine had a squeak and tapping a low speed, after my second visit to the dealers it turned out to be bent/damaged brake cooling duct.
Post #494352 Sun Apr 24 2016 6:23pm
wilf
It does sound like a dry suspension bush somewhere. Does it go away or get better in the rain? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #494365 Sun Apr 24 2016 7:16pm
Humbug
They haven't been changed – the noise is on the move from the front end/underneath – but interested to know why might this make a difference as I use the park brake a lot (I've found that holding the car at a roundabout in 1st on the brake ensures the quickest pick-up).
I think it must be something to do with suspension mounts, though. Haven't noticed a difference in the rain but will check if we get wet weather.
Post #494380 Mon Apr 25 2016 8:49am
wilf
Well, it is still under warranty, so if I were you I would give it back to the supplying dealer, demand a replacement vehicle, and not accept it back until they had fixed it.
Maybe call LR assist? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #494394 Mon Apr 25 2016 12:36pm
Humbug
It's in for three days from Wednesday to diagnose and fix so if they can't sort it I guess that's what I'll do. It has done 45k in just over 2 years so I think I've got to give them another chance before I get too punchy. Just hope they can work out where the noise is coming from.
Post #494398 Mon Apr 25 2016 1:15pm
Humbug
Ended up being a severely worn ball joint at the front. All good once the fault eventually found – I've got an almost completely new front suspension because they've replaced so much... (Through all the time the car was going back and forth the repair centre was a pleasure to deal with, even as they failed to work out what the problem was – maybe because they're not a dealer?).
Post #495039 Tue May 03 2016 9:27am
