![]() | Home > In Car Electronics > Upgrading 2012 screen to Dualview unit possible? |
It was well over a year since his last post, I may have misread your post, but if you have a dual view, surely no need to swap it all, just don't press the button for dual screen and leave it working as normal. That's what I do, the only time I use it (dual view) is if my good lady wants to watch TV or a DVD film on the move. So I would save yourself some money as no swap required. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5041 ![]() ![]() ![]() |
My A/B has the Dualview screen, although very clever I have only ever used it a couple of times to see if it still works, I rate it as just another L/R gimmick, they would have been better off concentrating on getting the Sat Nav and Audio Side perfected. I really wouldn't worry about it if it hasn't got it fitted if the rest of the car is A1. This is only my own personal view (no pun intended) of course.
I’m resurrecting an old thread here in the hope that someone may have made progress with this in the last few years.
As an update to this in case anyone else has a go, the Tv issue is fixed, when playing with the CCF I switched on RSE and as the RSE module is the first to receive the Tv signal, it wasn’t fitted and therefore couldn’t forward the signal on.
All sorted, there’s at least 3 files to update and one is very obscure. I ended up changing 5 files to find the obscure one so tomorrow I’ll switch them back one at a time until I find the one that worked. 2019 5.0 SC SVA (Current)
