Home > General > Unleaded vs Super Unleaded |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Hi captain and welcome, I think you've opened a real can of worms with this one. Though I'm coming from the diesel side I only use the good stuff , nobody can prove it either way but if it helps clean the fuel system then Its less wear in the injectors which makes them last longer then I'm happy to pay a little more at the pump. 2008 G4 RRSport TDV8 current
Mon Mar 21 2016 5:47pm |
Tome Member Since: 20 Mar 2016 Location: West midlands Posts: 21 |
I have not got a rrs yet but im my bmw petrol i dont get any more mpg to be honest but it is a lot smother when underload and at idle and when ever i change the plugs there never black or nothing. So i dont think you get any extra miles as petrol is concerned but deffinetly worth the extra pennies imo |
Mon Mar 21 2016 5:58pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2794 |
All my Sports have been run on the Shell VNitro + fuels both Petrol & Diesel - a few pennies more for piece of mind IMO but still can't find any real hard evidence that it makes a difference BUT can't believe it can be advertised has having those extra properties if it DOESN'T 16MY Estoril Blue SVR.............
Mon Mar 21 2016 6:17pm |
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 |
Funnily enough I watched fifth gear last night and they were testing premium unleaded vs cheaper unleaded. There was a 4 bhp difference between the most expensive and Asda fuel which VBH said she could feel. This was tested on a 250bhp VW golf.
Mon Mar 21 2016 6:27pm |
NigelM Member Since: 08 Jan 2016 Location: Essex Posts: 19 |
I was told by someone who should know about these things that it's not worth it for petrol unless you are chasing the last couple of hp, but for diesel engines that have a DPF it is well worth spending an extra 10p/litre, especially if driving something like an Audi which you can't regenerate and have to pay Ł1500 for a new one when it becomes blocked. |
Mon Mar 21 2016 7:50pm |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 |
Funny only ever Asda fuel that caused "water in fuel messages" and only one Asda location at that, stopped using that location,many no more water in fuel messages ..... |
Mon Mar 21 2016 8:37pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
I have a 4.2s/c here in Aust.
Tue Mar 22 2016 5:56am |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Premium fuels are a way of extracting more revenue from people who can afford it, whilst not losing the customer on a lower budget to cheaper competition. Analogous to Grande vs Venti in coffee shops or first class travel. Or HSE vs Autobiography. So massive opportunities for profiteering.
Tue Mar 22 2016 6:31am |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
I think that using a filling station that is busy is more important than the octane rating. If you put in ultimate or v power that has sat in the tanks for a long time it will have lost its benefits.
Tue Mar 22 2016 9:35am |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
In case of a supercharged petrol the only thing important is how much can the engine ECU advance the timing. In a supercharged car (boost is relatively low and very predictable with the RPM) the ignition maps are safe for ~95 RON/MON octane fuel and IIRC - correct me if I'm wrong - the RRSC ECU allows for some ignition advance, however in no circumstances, no matter what fuel you put into the tank, it will not develop more than stock HP, because in order to extract more HP, ignition advance must be pushed beyond the capabilities of the stock ECU. An ECU program upgrade by itself will not extract more than 5, maybe 7% power from a RRSC (no boost change). Change the boost (think: smaller pulley) AND the ECU software, and you'll see 10, 15% increase in HP if the fuel used is high-octane: more boost, more ignition advance, high-octane prevents detonation, profit.
Tue Mar 22 2016 10:39am |
