Home > Technical > A Bit of advice |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
I'd be very surprised if the poly bushes were causing this. it sounds like they are trying to get out of fixing it to me.
Sat Mar 12 2016 2:33pm |
rajhirani Member Since: 05 Mar 2009 Location: london Posts: 53 |
Hi,
Sat Mar 12 2016 4:17pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Do you have the print out from the alignment check? No print out, no alignment check. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 12 2016 6:17pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
As you said, take it to your local indi and see if they can find the fault.
Sat Mar 12 2016 8:01pm |
Hi All,
Thu Apr 14 2016 4:19pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Contact your trading standards if you are not happy. John
Thu Apr 14 2016 5:08pm |
ozzievechi Member Since: 14 Mar 2016 Location: london Posts: 55 |
most main dealers are all scum bags, may I ask what franchise this is? I would advise going to LR directly and see what they can do.... currently having an issue with Shatstones and now the franchise director from LR has got involved as their service and attitude is embarrassing |
Fri Apr 15 2016 9:15am |
I've got poly bushes in the front of mine and they do make the ride noticeably harder. It's not harsh, but certainly not as soft as with OEM.
Fri Apr 15 2016 9:49am |
