Home > Technical > Suspension wallowing.
steve65
Hi, forgive me for my ignorance! I am new to these vehicles, I have a 2008 RRS, when I drive it along country style bumpy roads, it seems to wallow around on its suspension. It does not feel really stable, is this normal? The compressor was changed recently and it seems worse since. Thanks, Steve. P.S. My rear anti roll bar bushes are tired, what type would you recommend using, std or poly? Suppliers?
Post #490036 Sat Mar 05 2016 3:32am
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Hi steve
I can't comment on the bushes, but from my own car I would say wallowing Is not normal. If anything I have observed my car being too firm. I test drove about 6 cars and they all felt firm when on winding roads etc.
Maybe someone more technical can add.
Cheers Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #490050 Sat Mar 05 2016 8:56am
Jaggs
Does it have ACE fitted you can tell by looking behind drivers headlight, if there is a reservoir with a yellow cap on just behind headlight it does and you shouldn't get much if any roll on cornering / bends Nanocom Evo
Post #490056 Sat Mar 05 2016 9:12am
Tim in Scotland
Steve's car is a TDv8 so it has the Dynamic Handling pack as standard, worth checking the hydraulic fluid level, but I would have thought that if the handling was way out due to lack of fluid you would get the warning light on the dash with the car with left and right arrows over it. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #490063 Sat Mar 05 2016 9:45am
steve65
Ok thanks, I will check the fluid etc, the car just seems to float on uneven surfaces and feels unstable on the back end if you run over a rut in the road. I have had new bushes on the nsr corner and 4 wheel alignment carried out, body roll seems minimal though?
Post #490072 Sat Mar 05 2016 11:56am
steve65
Tried it out over the weekend, the fluid level is ok, it seems to be the rear that bounces and floats over the bumps, dampers maybe?
Post #490413 Tue Mar 08 2016 8:15pm
DrRob
Take it to James French to sort....... Visitor from fullfatrr.com
Post #490416 Tue Mar 08 2016 8:37pm
steve65
Thats where it came from! It had the worst case of corroded rear brake pipes the MOT tester had ever seen!
Post #490419 Tue Mar 08 2016 8:49pm
steve65
I am trying to work out which rear anti roll bar bushes I need, so do I order the ones for a vehicle with ACE?
Post #490722 Sat Mar 12 2016 5:54pm
steve65
Anyone?
Post #491258 Sat Mar 19 2016 2:27am
TDV8 all have "ACE" although that is an old term for it.
http://www.advancedfactors.co.uk/rvu000022...2118-p.asp 2012 SDV6 - it's missing a couple of cylinders
Post #491288 Sat Mar 19 2016 4:18pm
shakeapaw
I can scare myself sometimes how fast this car will take country bends with ACE fitted, I had the standard bushes replaced with Land Rover standard ones as my Indie had, had complaints about the Polybushes being too hard 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #491290 Sat Mar 19 2016 5:06pm
I don't think wallowing in corners is the ARB bushes anyway. Worn ARB bushes make a knocking noise on uneven surfaces. It's very obvious. Wallowy handling is more likely to be tired dampers. It might be worth having the dynamic response system bled and/or a new filter put in the valve block (on the chassis rail below the driver's seat if you look under the car). The ARB drop links aren't expensive and can wear putting some flex in the system.
The problem is that what you think is wallowy handling is actually what these beasts do. They're 2.5 tonne lumps with air suspension; sports car handling is not what they do, no matter what Land Rover might suggest. Even the best - the SVR - is still a big 4x4 and won't feel like an Elise when thrashed. It might still be quicker from A to B though! Twisted Evil Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #491292 Sat Mar 19 2016 5:46pm
steve65
I think may you be right, we have not had the vehicle very long and it may just be down to my inexperience, the more I drive it the more I like it! I think maybe I am now getting used to the air suspension. Still have the bushes to fit to sort the clonking.
Steve.
Post #491845 Sat Mar 26 2016 11:56pm
DrRob
Not sure how far from you but TS Norman are highly rated on here Thumbs Up
www.tandsnorman.com Visitor from fullfatrr.com
Post #491861 Sun Mar 27 2016 8:08am
