![]() | Home > My Range Rover Sport > My first RRS tdv8 3.6 |
edviss Member Since: 29 Feb 2016 Location: london Posts: 28 ![]() ![]() ![]() |
everywhere says that tdv8 is from 2007, but my one is 2006/06 |
Unclebuck Member Since: 04 Dec 2014 Location: South Yorkshire Posts: 51 ![]() ![]() ![]() |
If it's any help I had the dreaded front suspension knock , changed everything that was listed on the forums but to no avail but then came across a Service Bulitin saying something like 'if the customer still complains of a knocking from the front end remove both front and rear dynamic response shock absorbers, if the noise disappears just put the rear ones back on and leave the front ones off' or something like that , so I removed just the front ones (they are hidden in the front wheel arch area) and my knocking disappeared ! These shocks are about 8" long and mine were solid with no movement at all! Hope this helps ok |
All faults are fixed now, car has no more issues. just came back from euro trip drives absolutely amazing. done 8k
