Home > Maintenance & Modifications > Still can't get these f**king exhaust tips fitted!!! |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 533 |
John,
Sat Feb 20 2016 4:43pm |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
Looks as if you have a sleeve to fit over both exhaust and tips. Will they expand out a little as they do need to be fairly tight it looks as if you might have had the clamps over the tips if so try filing the outer edge of the exhaust pipe and perhaps cut a slot in it. |
Sat Feb 20 2016 4:59pm |
4X4BYFAR Member Since: 14 Feb 2016 Location: West Midlands Posts: 57 |
This post has been edited by the site administration team
Sat Feb 20 2016 9:21pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
I would think the clamp you have would expand 4 mm but if not pop down to you local exhaust place with the new tail pipe in hand and they will have them in stock I would think, even quick fit.
Sat Feb 20 2016 10:36pm |
Not sure where abouts you are in Essex but you could try Haywood and Scott Exhausts in Basildon. They have been going for about 30 years and are specialists at making stuff from scratch. I'm sure they could knock you up some sleeves and clamps for you or even fit them.
Sat Feb 20 2016 10:46pm |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 |
Agree as everyone else has advised. Simple easy solution to that, and no more agro.
Sat Feb 20 2016 11:36pm |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 |
Thanks for your help guys,
Sun Feb 21 2016 7:37am |
Finally sorted!!!! 😀
Sun Feb 21 2016 7:12pm |
tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36 |
hi john you can get sleeves of ebay. about 15 what I did is 62mm and 58mm that way one side goes over the exhaust and the other side goes in to the exhaust tips. and then clamp them on but you will need to measure yours exactly. |
Sun Feb 21 2016 7:23pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
at last Well done 16MY Estoril Blue SVR.............
Sun Feb 21 2016 7:26pm |
