Home > Faults & Fixes > Front parking aid inactiveI the
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Re Parking Aid
Thanks very much again Bud ,Will let you know how I get on. Thumbs Up
Post #488563 Mon Feb 22 2016 9:06pm
ragpicker
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Sumatra Black
denlaa wrote:
Hi John, no problem at all mate, hopefully you won't need it but the same offer is there for the loom if you do. I spent £500 getting them all working again just for them to annoy the Censored out of me every morning when I'm leaving my drive!! Smile
Im about to investigate the parking aid issue on my 08 RRS. Am going to try to have a listen for the clicking first. If it sounds like a faulty sensor would I be able to take advantage of your kind offer too, denlaa?
Post #491867 Sun Mar 27 2016 9:19am
denlaa
United Kingdom 2007 Range Rover Sport Supercharged Buckingham Blue
Hi, yeah that's no problem. I have about 3 sensors left so just let me know what you need.
Den
Post #492094 Tue Mar 29 2016 3:47pm
Billyblue02
England 2012 Range Rover Sport SDV6 HSE Santorini Black
Any advice on listening for the clicking sensors on a 12 plate as I can only do it with the engine running ( cos of the retracting gear nob) can't hear cos of engine at front exhaust at rear ??
Post #492869 Tue Apr 05 2016 9:14pm
Citizen55
United Kingdom 2006 Range Rover Sport Supercharged Tonga Green
Stethoscope ?
You could try putting a drinking glass over it and put you ear against it? Might be a silly idea but it works for listening to your neighbors through the wall haha. 2006 Range Rover Sport 4.2 s/c with Arden bodykit
Post #492904 Wed Apr 06 2016 7:20am
ragpicker
Sorted mine. In the end it was the drivers side corner one.
It wasnt clicking at all where the others were. The clicking is loud enough to hear over the engine ticking over.
What a Censored to remove though! I took the fog lamp out and tried to push it out from inside the bumper. In the end I had to tease it out with some trim removal tools then wrap wire around the sensor under the lip and pull.
There has to be an easier way!?
Anyway, once its out the sensor just unclips from its housing and pushes back in. Dead easy! Thumbs Up
Post #492922 Wed Apr 06 2016 8:55am
MrGimper
England 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Did you pull it out the front of the bumper, or did you push it thru back into the bumper? I can't work out which way to go.
Post #574754 Thu Feb 07 2019 3:27pm
MrGimper
Post #574755 Thu Feb 07 2019 3:28pm
MrGimper
Re: Re Parking Sensor
Jock 77 wrote:
Cheers for the reply
Managed to remove my sensor last night through the Fog Lamp hole Thumbs Up and its a straight one Valeo part number YDB 500301.
When I was listening for the clicking I had switched the car of in either Forward or Reverse with wheels chocked and then turned ignition back on till dash lit up and could hear the sensors better with no engine noise.
I have bad ears though Laughing
Cheers Jock
Post #574756 Thu Feb 07 2019 3:28pm
Jock 77
Re. Parking Sensor
Hi there from what I remember I pulled them out from the front of the Bumper. Think they had a couple of small legs that need pushed in to do this though.
Think it was quite awkward to squeeze these in through the Fog Lamp hole but you just have to persevere.
Post #574816 Fri Feb 08 2019 11:31am
MrGimper
Thanks for replying. In the end I managed to remove the headlight and get a bar down to lift a clip and then use a punch to knock it back into the bumper. I still have the scars!
Post #574817 Fri Feb 08 2019 11:35am
foxy69
Wales 2006 Range Rover Sport 4.4 V8 HSE Baltic Blue
Parking sensors??
Gday all, thanks for all the helpful tips on here. I have the inactive parking sensors message on my dash. I have changed the front off side sensor and now they are all clicking front and back but I am still getting the message and flashing switch on the dash. I have just replaced the battery and now disconnected it to see if that will clear the fault??
Does anyone have any further advice what else I need to check/do as all sensors are clicking?
Thanks Steve
Post #577354 Tue Mar 19 2019 12:51pm
