Home > Technical > Flashers too fast right side, RRS 2.7 2006
41664166@online.no
Norway 2006 Range Rover Sport TDV6 Autobiography Rimini Red
Hi
Someone who can tell why my flashers right side flashing to fast
This despite the fact that all bulbs are okay
Could it be relay cheater?
Where, if desirable sits this?
What is the correct part number for a replacement?
Its a Range Rover Sport 2.7 2006
TrondL
This post has been edited by the site administration team
Extra Large font removed
Post #486857 Sun Feb 07 2016 5:46pm
Bodsy
Site Sponsor
Do you have LEDs fitted? Is it the external actual flasher that is too fast or just the flasher on the dashboard? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #486867 Sun Feb 07 2016 7:39pm
41664166@online.no
Have Led mounted both front and rear .
Is it both the external (only right side) flasher and the dashboard that is too fast
But this happens only periodic occasionally
TrondL
Post #486903 Mon Feb 08 2016 2:14am
41664166@online.no
Where is the relay located ?
What is the correct part number for a replacement ?
Post #486962 Tue Feb 09 2016 4:42am
if its LED, do you have the Canbus style Led's? LED draw so little current that a car can think the bulb is not working, hence the rapid flashing
Post #486978 Tue Feb 09 2016 10:34am
41664166@online.no
How too fix that
It`s only on the right side flasher
Post #486979 Tue Feb 09 2016 10:37am
I would assume you need to buy canbus style LED's or place a resistor inline
Does the car still do this with standard filament style bulbs?
Post #486980 Tue Feb 09 2016 10:49am
41664166@online.no
What about a flasher relay for LED lamps ???
Post #486982 Tue Feb 09 2016 10:55am
Lost for Words
In common with most of the lights, the indicators are controlled by in-built FETs in the CJB (passenger fusebox). You need not just CANBUS LEDs but proper resitors fitted to get a reliable result so if you don't have these then that's your issue. Thumbs Up Visiting from DISCO3.CO.UK
Post #487007 Tue Feb 09 2016 5:46pm
41664166@online.no
Where too buy and where too mount them
Post #487054 Wed Feb 10 2016 2:10am
Lost for Words
50 Ohm ones are suggested to keep the amount of heat generated down - bear this, and water ingress, in mind in terms of location; can't be more specific not having a RRS I'm afraid. You should be able to source them from a typical electrical supplier. Thumbs Up Visiting from DISCO3.CO.UK
Post #487060 Wed Feb 10 2016 9:03am
41664166@online.no
Dashboard flasher flash fast
I have the LEDs fitted in the rear on my RRS 2006
The external actual flasher flash normal,.. but the flasher on the dashboard flash very fast both side
What too doo ??
Post #505450 Wed Sep 14 2016 5:35pm
Johnski
Believe it or not, the legal flashes for indicators is between 90-120 flashes per minute.
Many new cars don't meet this legal requirement, but it is occasionally used by the Police if needed, but is still on the books as a legal requirement, although you don't see MOT stations count the frequency unless an obvious fault.
Another old law still relevant and never repelled, is you shouldn't park closer than three feet from a kerb. Whistle
Evidently going back to the days before cars when rubbish etc was dropped from upstairs levels for collection.
Plenty more useless facts available if you research, can you imagine what would happen if you tried to park like that now? Rolling with laughter Rolling with laughter John
Post #505453 Wed Sep 14 2016 5:59pm
http://www.powerfuluk.com/range-rover-spor...r-kit.html
Post #505457 Wed Sep 14 2016 6:51pm
Strange I thought the still did, I didn't think they fitted indicators these days either as you never see them working. Rolling with laughter
Post #505458 Wed Sep 14 2016 6:54pm
